'89 CV Exhaust Video (DUW)
    I was bored today, so I decided to make an exhaust vid. The sound quality isn't terriffic, but you get the idea.
    Enjoy...or don't. The choice is yours.
    http://s120.photobucket.com/albums/o...t=P1110253.flv
    Sounds ok. Are you running the stock dual exhaust? And I suggest that 4bbl swap sometime soon if you can. If you're running the stock exhaust, maybe move up to 2.5", i'm not sure if that's too much for a 351. High flow or no cats and flowtech glasspacks(those are really cheap).
      I've got both cats and glasspacks right now. Haven't decided yet whether 2.25" or 2.5" exhaust would be better, but it'll definitely be one of the two. No cats (no sniffer in MN ) and some variety of performance muffs (most likely Super Turbos).
        I say ditch the cats and go with 2.5" with glasspacks.
          I AM ditching the cats.
          And Super Turbos are gonna flow better than glasspacks.
            Yes..........YES!!!!!!!!!
            Good stuff
              We should do one of Vicky she sounds BEASTLY!
                Ouch, all that revving on a cold motor? Sounds good though.
                Nick
                88 Colony Park LS
                  Who said it was cold? I drove it around for like 45 minutes before doing that.
                    I just got around to seeing this. Sounds good!
                      Looks like you an exhaust leak up behind the passenger front tire. It'll be so much nicer when you get those cats off.
                        Two, actually. That's where the air lines used to go into the cats. That whole system will come off one of these days when the 2.5" system goes on, and then the Linc will get the 2" duals.
                          351W talk is music to my ears. Sounds good and strong.
                            Yep. 154,000 miles and it'll still hold 43 pounds of oil pressure all day long.
                              I thought I heard a high idle at the beginning. My bad.
                              Nick
                              88 Colony Park LS
