The Hillbilly Deluxe race limo
    Well, some weeks ago I finally got pulled over for blinding a cop with my 4-lo converted headlights, so last Tueday I spent over an hour in re-aiming the headlights. Results were good, but just to be on the safe side yesterday made these too:
    They are 2" wide so they should quite effectively limit the light shining into on-coming drivers eyes, without decreasing the output towards the road. JC Whitney sells something like that too, but I decided to save myself $20 and make them myself, if nothing else at least I know they fit nicely. After installing them I had a choice of crome or blacked-out bezels, threw the crome ones on as otherwise there would be too much black in that area and non on the marker lights (not balanced view).
    Also I have new fog lights - those took me a whole freakin evening to install, but I think it was worthy. They have sturdy cast-aluminum shells (and not crappy plastic ones), and come with decently stable steel brackets that I'm supposed to bolt down where I want the lights. Well, I didn't bolt them down, I directly welded them to the bull bars - it doesn't get stronger than that, lol. Kit came with the lights and all mounting hardware, a pre-made harness (was quite impressed by the quality), relay, fuse, and an LED push-switch that can be mounted pretty much anywhere. I ended up not using the fuse, the relay, and the switch with its wiring, instead I made the fog lights automatic - they come on with the marker lights, turning the low beams on kills them swithcing to highs re-activates them. Two relays connected in series are required for that, the first one activates the circuit with the marker lights (power for the control loop is taken from the front passenger side marker light), and the second relay interrupts the circuit when the low beams are activated (control loop takes power off the low-beam relay on the passenger side of the car). When the high beams are activated power to the low beam relays is turned off, which means the foglights interruptor relay goes back to its default state of "always on" and fog lights come alive again. Fog lights are rated at 55W each so now I have some quite decent power output levels:
    - marker lights 110W
    - low beams 220W
    - high beams 370W (260 highs + 110 fogs)
    Fog lights are amber by the way, and although I haven't had the chance to try them in some extreme weather conditions based on my experience from last winter they should work quite well. Now, pics:
    Compare the last two images, that's the difference between black bezels and no shades, and crome bezels and black shades.
    And did I post pics of my T-bird shifter with the new center console behind it? Don't think so, so here they come, fresh off the digicam:
    This time I actually did it right and took the time to cut the console so it fits over the driveshaft tunnel nicely and bolted it down, also for cleaner looks I cut two openings in its sides and routed the seatbelts through there. On top of that now even the rear seat passengers have cup holders. The only thing still missing is the 110V outlet, but it's on its way in too, just a matter of time really
    That's all for now, I think. Done bragging, time to sleep :p
    P.S. my Supermotors webpage is all updated and reorganized now, take a look if intersted.
    Nice custom work!What car are those seats from?
      Thanks! Seats are from a 2000 Dodge Neon SXT got the complete set (including the rear seat) for $50
        Howd u make and install those, i want me some..
        '95 Ford Bronco XL -
        sigpic :rebel:
          The headlight shades? You take a strip of steel (preferably stainless, but I didn't have that), and bend one of the long edge up so you end up having a lip that is between 1/16" and 1/8" tall. Take one of the headlight retaining rings off, touch the metal strip to it and measure how you'll need to bend it so the flat surface lies smoothly along the inside edge of the retaining ring, the lip you just bent will then get clamped between the retaining ring and the headlight's glass (that's how you mount them actually). Cut the small lip off at the areas where the strip will get bent, bend the strip, and cut the flat sides off diagonally. Slide the now ready headlight shade inside the reatining ring, mount the pair to the headlight. Done, enjoy! The strips I used for my shades are 2" wide, more than that would be overkill I think.
            Your car is awesome! I've always liked what you have done to your TC.
            I've been considering making light shades for my car...But am not sure how it would look on an 88 Grand Marquis.
              Mr Marquis, thanks! The headlight shades installed on your car will look similar to mine, maybe even better as your headlights are closer to each other. To retain the more aerodynamic lines I'd suggest that you make the shades no wider than 1" (mine are 2"), and also make them out of stainless steel (you can always paint them later). If you decide to paint them right away go for body color - saw an old Kenworth 900W like that once, it was yellow with green stripes on the sides, the headlights were yellow with crome rings and green shades (windshield shade was green too), loked pretty badass. Besides with the body color you're almost guaranteed to be the only one with that color combo
                Do you have an *official* readers rides thread? there arent enough towncar stickies
                  Nah, no official thread, car isn't special enough to be stickified, besides we have way too many stickaroos as is.
                    Is the shifter functional? Did you change the lever on the side of the trans to make it work or did you come up with alternate cable routing to get around that?
                      Got pulled over for the same thing! We where comin back down a mountain road from a kegger and got busted......allmost.....and we forgot the drivers licenses at home ...god we were lucky..LOL
                        Ya, shifter is fuctional, why would I have it there if it ain't working? There's no cable anymore, I never liked the idea of it, and even if I wanted to use it I couldn't:
                        - at that particular location where the shifter is mounted there's not enough spaceunder the tranny tunnel sheetmetal to clear the cable brackets,
                        - the T-bird tranny lever (required to maintain shifter leverages) if mounted like it should to be able to use the cable wouldn't clear the exhaust (glasspacks are right next to tranny).
                        What I did was flip the T-bird tranny lever uspide down (it fits very nicely, even clears the TV cable and lever), and connect it to the shifter via a linkage rod, similar to what Lokar use but without the heim joints. The rod had to be given some bends in order to clear the VSS, but overall it's pretty straight and feels damn solid. Also inside the tranny there are now two detent springs for the main shifter lever, the original TC one and the one from the T-bird (wheel cut off obviously) right on to of it - this requires more force applied to the shifter to move it from gear to gear, but it also makes for more positive shift lever location in the tranny and much better overall feel of the whole system.
                          Well I had no problem at all, until I put the big tires on - the whole car went like an inch up, which apparently was enough to start shining into people's eyes. It's all fixed now, and those shades I have actually work quite well.
                            Hey that is the same shifter I had in my old mustang COOL ...It was a 2.3 that I was going to do a turbo swap in. I had to customize the shifter to make it shift a C4 trans ..Any way thats cool
                              Hey Ivan it just keeps on getting better and better good job mang
