I noticed this today... I have been worried about this bubbly spot and it recently came through (yes all the way through).
There is also rust on the underside of the crap chrome trim, and I saw some from the inside down there when I re-did the trunk carpet. At that time, I tried to sand and I just covered it with rubber undercoat spray... not a fix I know.
I want to remove the trim to expose whats underneath, and Im a little scared. but Im going to do it, becuase if I stall it will just get worse, and I want to do something while its still unnatrually warm here.
Any one removed this trim before? I see two screws on the fender well, but how does it come out from there? Does it slide off? will I need to take the wheel off? I dont plan to put it back on, so I dont care if it gets damaged.
Tom??? help!!!
What do I do for a temporary hold back, and for a more permanent fix? ( I dont care what it looks like, white primer is becoming more and more of a color on this thing.
How do you patch the hole??? I am sad
Tom??? help!!!
