I took GO to an automatic car wash a little while ago and I could hear dripping through my door. Is the felts or the weather stripping?
Drip, drip, drip
probaly the window crap letting water through the door and draining out the drain holes in the bottom, its what mine doesjay--1983 towncar, 302v8 cfi, dual straight pipes w/resonators ,edelbrock motor goodies, custom interior, full custom stereo system, full rebuilt trunk audio setup, custom paint...more to come......
The rubber scrapers on mine are shot, and it leaks through them. Just make sure the drain holes at the bottoms of the doors are clear. When I first got my car, I shut the door and it splashed on me. Damn thing was full of water. Cleaned out the drains and all sorts of crap came pouring out. Need to find a source for those scrapers tho.86 Lincoln Town Car (Galactica).
Our doors are designed to take in and drain water. The rubber squeegee things that swipe the glass keep debris out that would otherwise clog the drains.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
on either end of the bottom door edge there should be two spots that have a small opening in the lip.
On mine the sealer/putty stuff along the bottom edge was so warped you couldnt see em.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
