I have an 88 Grand Marquis. From the bodyline down i have some rust spots over the wheel wells and on the lower quater panels (Surface Rust)... Where that damn plastic trim that runs down the center of the doors is i have two holes on two of the doors. the question is do i fix the holes or do i replace the doors??? ( I have an 89 Grand Marquis as a parts car that has good doors!) and how hard would it be to replace the doors?? Depending on which way i go with the doors i will be throwing the plastic trim in the GARBAGE!!!!!!!!!!!!!!!!
Thanx PORKCHOP
Thanx PORKCHOP
