I was thinking about freshening up the steelies on the Vic. I was thinking repaint them with a gloss black, get some trim rings, a set of chromed lugnuts, and slip through center caps. You guys think it would look like ass? I think it would look tough, without giving it a coppish look if you know what I mean.
Would this look good?
It would look nice, yes. Good luck finding a slip-thru center that will fit tho. I think '99% of those are designed for aftermarket wheels with a big ass center hole.'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
'95 Ford Bronco XL -
sigpic :rebel:
Originally posted by Blaze86VicYou will not be able to run a pull though center cap on factory steelies. The center hole in the wheel is matched to the side of the hub, a sheet of steel will not fit inbetween the hub and the wheel.
Shit.Save a seal, club a liberal.
