What's the best way to clean them and prep them for paint? Just hit them with some 220-400 sand paper, blow them off with compressed air then brush on paint?
Cleaning engine parts like alternators.
Originally posted by N AWhat's the best way to clean them and prep them for paint? Just hit them with some 220-400 sand paper, blow them off with compressed air then brush on paint?
It is notorious for cleaning very well, drying fast, and leaving no residue..1983 Grand Marquis 2Dr Sedan "Mercules"
good carb cleaner I find generally works better. 2+2 = teh win for paint prep. Just be careful what and where you spray stuff. It will dissolve the varnish on the internal windings, possibly causing shorts. If you really want to paint it, I would probably take it apart and paint the case without the guts in it.86 Lincoln Town Car (Galactica).
Originally posted by 91gmblackDon't use carb cleaner, it leaves a mild lubricant on the surface.
Use brake cleaner.
:stupid:
2+2 doesn't leave a film. Cheapie Advance Auto crap does. The Wal-Fart junk does too.86 Lincoln Town Car (Galactica).
