Which paint scheme??
    I like the all black the best, get similar wheels and have it at the smae stance. It would look mean.
      Yep it should look bad ass!! Plus this gives me another excuse to try the rear spoiler I wanted to fab up for it. But I think I'll pass on a roof spoiler!!:nonono:
        I think the fact that me and you think alike often is scary.
          Yep!
          I'm trying to figure out where to get some BFG radial T/A's that are that huge! They look wider then a 295. The only tires I've found that are the size I want in a radial tubeless tire are the Hoosier pro street radials( 29x12.5x15 ). I can't afford to run drag radials.
            It's actually a small car, so keep that in mind when you try to visualy judge the size of those tires. I think 295 is pretty close to what they are, if not wider than what they really are.
            BTW, would you please post a link to his page? Or are those pics that you have?
              run them on a 15X10 or so...
                I still think those BFG's look bigger then 295. I ran 295's on a 90 Mustang coupe and they didn't look that wide. But you never know. I want to run the Hoosiers I mentioned but they run $222.00 each. So I'll probably be stuck running the BFG 295's. I'm going with 15x10 rear rims.
                I got the pictures from this website. http://www.popularhotrodding.com/fea...405phr_falcon/
                  Just make sure they stick out of the wheelwells, and use airshocks (or cargo coils, till u sold em) to jack that beeotch to teh moon!!
                    If I can ever afford the Hoosiers they'll definately stick out(12" wide ). And I plan on getting another pair of cargo coils when I get to the point of needing them.
