I like the all black the best, get similar wheels and have it at the smae stance. It would look mean.
Which paint scheme??
Yep!
I'm trying to figure out where to get some BFG radial T/A's that are that huge! They look wider then a 295. The only tires I've found that are the size I want in a radial tubeless tire are the Hoosier pro street radials( 29x12.5x15 ). I can't afford to run drag radials.
I still think those BFG's look bigger then 295. I ran 295's on a 90 Mustang coupe and they didn't look that wide. But you never know. I want to run the Hoosiers I mentioned but they run $222.00 each. So I'll probably be stuck running the BFG 295's. I'm going with 15x10 rear rims.
I got the pictures from this website. http://www.popularhotrodding.com/fea...405phr_falcon/
