It was close to 50 degrees today so I went out to the storage unit and removed the vinyl top off the LTD. I found one fairly large rust hole and one pin hole rusted thru the roof.:pissed: I still need to pull the trim and remove all the fuzz and adhesive. Then I'll have to weld up all the holes. Hopefully I can get it done without warping the hell out of the roof.
