Found a writeup for fixing water leaks from the firewall on a 92 Crown Victoria. The HVAC drain flap needs to be resealed with putty thrugh the wheel well with pulled apron.
Does this also work on our boxes?
My passenger side carpet and, more severe, the factory sound proofing underneath is soaking wet. Had to pull the rubber grommets in the pan and wring out the padding to let it drain. Water leaks in from the right hand corner firewall. I had suspected the broken caulk on the large hood hinge bolt, but found the HVAC drain flap writeup and thought that this sounds more like it.
Carpet and padding was bone dry when I bought it in May. Car sits out all the time and we have lots of rain this year. So it clearly accumulated.
