Hi,
Is this done by drilling out the weld points, and the what on the c-pillar, grind it out?
Wondering if the seam is all the way near the roof weld point.
Have a wheel well smoosh back from college that I’d like to remove, but not much access from rear seat with wall card removed, even with a hook. Smoosh is on small ridge of wheel well flange pushed in a bit. Figuring I would need to separate the wheel well and quarter panel.
Tack welder won’t work alone.
Thinking about building up garage: compactish english wheel, various spoons, shot bags and teardrop mallets.
