Does anybody have any tips or warnings for welding body panels on cars with an ECU? I am going to replace the driver's side floor panel from front to back. For whatever reasons, that side rotted out pretty bad. The other side has been oil-slicked and is rot-free. I will cut the floor out of the '88 MGM at the junkyard and weld it in place of the CV floor. I don't know how that will affect the ECU.
Welding
Disconnect the battery just to play it safe.~David~
Some will say its fine, but why risk it? Me I would pull the terminals on the battery to be sure. I hate electrical problems because they can be difficult to figure out. You can even remove the computer if you wish.~David~
Mine has been welded on a few times, other than unhooking the battery no special precautions were taken. ECM hasn't blown up.86 Lincoln Town Car (Galactica).
ditto.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Always unhook the batteries both + & -
Set you ground clamp as close as possible to the area to be welded with a clean connection.
The key to this is the elimination of the weld circuit searching for a path of least resistance for a ground. Fried electronics are not good..
also ecu has a pretty simple plug to disconnect for the full protection factor
I didn't disconnect anything on the 88 when I welded the driver inner door skin back together. But I didn't turn on the car while I was doing that either. I was using flux-core wire in a cheapo Harbor Freight 90A welder... so I doubt there was much chance of anything going wrong. Didn't cook anything either.
There is no issue with brazing or torch welding since you're just using heat.
other than risk of fire of course. I prefer torch welding. can't see for shit with the electric metal glue gun and the results are predictably horrible. Brazing or torch welding is like big-boy soldering and I can see what I'm doing.86 Lincoln Town Car (Galactica).
