Grand Marquis Trim Package?
looks aftermarket, and honestly kind of terrible. Kinda reminds me of a Dodge Dynasty grille. Either way it doesn't really seem to fit the car properly based on the hood ornament pitch.86 Lincoln Town Car (Galactica).
That’s one of those “Rolls Royce” knockoff grilles with a ‘88-‘91 hood ornament just jammed in there. Definitely not factory or dealer addon, just one of those blingy things that look bad.
Assuming it runs nice for $1 you could splurge to make it stock and still have a great deal.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Does not look too bad overall if I block out the grille from the pictures. lol
Check out the wheel well arches really good. Those aftermarket trims may be hiding something. Also, what is up with the drivers side rear door. It has some weirdness about it up above the window....Something is funky about the drivers side lower bumper as well.Last edited by 87gtVIC; 01-27-2019, 03:05 PM.~David~
Exterior looks pretty beat, but certainly the opposite on the inside.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
If I needed good cheap transportation i would look at that.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
for a grand its not a bad deal, junkyard trip for a stock grille will have it back to decent. Just make sure you look close for rust, especially hidden under the chrome wheel arch trim. Thats a common old trick to hide rust just starting to form.86 Lincoln Town Car (Galactica).
Originally posted by 87gtVIC View PostDoes not look too bad overall if I block out the grille from the pictures. lol
-1994 Lincoln Town Car...always under construction
I saw this car while searching CL last week. I thought the grille looked like an early aero TC grille but after looking at some aero TC grilles I don't think so.
+1 The funny angle of the hood ornament says not professionally done (dealer add on, coach builder, upfitter, etc.)
Also, is the rear driver side window taped up? Might need a new window motor or the cable is off track or snapped.Last edited by VicCrownVic; 01-27-2019, 11:02 PM.Vic
