My MGM has or I should say had a probably dealer added hand painted pin strip down each side, over the years of washes and waxes plus the Florida sun this strip has faded to the point it just made the car look bad.
At one point the previous owner had body and paint work done to the drivers side front fender with what looked like a new hand painted pin stripe only on the drivers fender.
My plan was to slowly work all the panels by washing them, using a clay bar on them, having Paintless dent removal on some small parking lot dings then touch up the paint then finally have entire car professionally polished.
This would have left just the rear bumper needing to be worked and painted.
Yesturday I was hoping I could just take some Acetone and rub off the old pin stripe with little effort. Well it worked great on the orginal pin stripe yet I found out the hard way the new pin stripe was put after clear coat like normal yet some how half of the pin stripe is buried under clear coat ( like it may have had a second repair at one point )
I guess I will be having more of this car painted than I wanted to.
If this car was painted any color other than white I would have been able to see the clear over the pin stripe, yet White is so blinding to look at it was easy to miss.
Had I known this before hand I would just paid someone to re pinstripe the entire car which i can still do but I will have a small area of clear coat that I will have to blend in somehow.
