How much paint and clear is needed to respray a Gm with a vinyl top? Same color and no primer; just sand back the clear, clean it, and spray it.
how much paint would it take?
Well if you're planning on doing the whole car you're going to want to use primer sealer too. Been forever since I've done something of that magnitude and it depends who you run with. For example: PPG basecoat clear coat systems have you reducing the basecoat 1:1 with solvent, so you could probably get away with a gallon of paint. I'd put three coats on it + one "Mist coat" to set the metal flake, otherwise you'll end up with "tiger striping" or modeling as its known in the industry. Primer sealer is important because it will prevent the other paint layers from coming back up through your new paint job, which happened to me as I was a cheap teenager once and needed to fix my broken trash.
So if it were me, I'd buy a gallon of primer sealer, a gallon of basecoat and two gallons of clear.
I really don't recommend you do it yourself as you need clean air and a good gun to do things right. Nozzle diameter is important as well as gun type, not to mention proper ventilation and a contamination free work zone with minimal dust, otherwise it will look like Maaco painted your car.1985 LTD Crown Victoria - SOLD
Honestly to save headache I would just repair what you have. I wouldn't replace the header panel or the fender.
I'd pick up a stud welder and start attacking the dent on the fender.
Fiberglass body fill whatever needs to be dont on the header panel (does not look bad at all).
Keep all repair areas as small as possible.
Pick up some 2k high build primer in aerosol form (spray max/eastwood) some primer sealer as well. Back mask the area TIGHT then feather the primer into the existing paint some.
Get some color matched base coat from http://www.expresspaint.com/ and blend in the paint.
I'd probably re-clear the entire fender or just up to a body line/pin stripe. Get 2k clear in aerosol form as well (spraymax). Whatever you do make sure to sand down the entire area to be cleared with some 1000 grit before painting the previously primered areas.
Keep it simple.. Don;t turn this into a huge project.
This is just a very quick explanation on how to do this easily and properly.
Ive had my entire car repainted. It take a lot of product. KISS.~David~
I second David's suggestions above.
If you find a good used fender, you could also substitute that. I have used color match out of a spray bomb on my 88. Matches darn good. Not perfect but darn good and 99% people can't tell.
If you aren't happy with the results, you won't have much in it and can go full scale later.1990 Country Squire - under restoration
Most shops wont repair that fender. It will be a DIY job at best. It is possible with the steps 87gtVIC mentioned but god is there a lot of room for error of the human kind there. Sanding, for example, is a work of art. Those who are good at it don't think twice but it's very easy to screw up body lines or make things look like a golf ball.. I wouldn't respray the whole car either, with where the damage is you could get away with a nice blend job but I would paint the entire fender. I'd have it all done though, I don't have access to the equipment needed and nor do I even have good lighting or a shop with adequate ventilation. Nope, nope and nope.1985 LTD Crown Victoria - SOLD
Yeah, my plan is changing; which is why I ask questions. I am not going to do the respray, a guy I work with does auto body on the side and I asked him to look at it and get back to me. I can also take the parts to the auto body school were I grew up, takes a while to get things through but if you can wait it's materials plus 20%. The concern I have now is the pinstripe, they are painted and under the clear aren't they?
Sent from my iPhone using Tapatalksigpic
Having connections helps. I had them long ago, not so much any more. Pinstripes are typically done on top of the base/clear -least that's the way they were done from the factory and they were done with paint. My Town Car got into a fight with the original owner's garage at some point in it's life and they removed the original ones to replace with the cheap tape type stripes because they were a cheap shop. I've since had the car painted and the stripes redone. My thread should have some pics.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostIt is possible with the steps 87gtVIC mentioned but god is there a lot of room for error of the human kind there. Sanding, for example, is a work of art. Those who are good at it don't think twice but it's very easy to screw up body lines or make things look like a golf ball..
I have a bunch of experience but am by no way an expert within this field. I get by just fine and have had good success after learning about bodywork for many years. I still learn things though each time I dive into a repair.
I have painted a set of BOX fenders in my backyard out in the open and everything went well. I waited a long time for the perfect weather conditions..... It can be done.~David~
When I move out East, I hope to soon after build up the garage with decent compressor, bodyman setup. Plan to redo car self, not necessarily a color change. Kolor has an interesting white aside from the oem PPG 9L.sigpic
1987 Mercury Grand Marquis LS 2DR
302CID, K&N air filter, Dual cherrybomb glasspacks, Vogue tyres (Front:P225/60R16,,Rear:P235/60R16), Centerline Pulsar wheels (Front:7", Rear 8")
COBRA 25LTD CB with/ Wilson 500 whip antenna.
