I don't know if this has previously been discussed so forgive me...I'm new to this site. I own a 2002 Grand Marquis which is beginning to form air/water pockets under the plastic covering on the silver door trim since it's started to rain here.... Can I take a razorblade and cut along the edges to remove this plastic?? Any advice on what to do or what to replace it with would be great...It's really ugly.
Grand marquis water pockets in door trim
I don't really know anything about that; about all I can say is I've never seen something like that before. Since no one else has chimed in, I'll raise the possibility that maybe someone put an aftermarket product on there. Are you able to peel a corner to see what's underneath?
That silver trim goes bad pretty fast, I'm surprised yours are still looking even that good. You can just pull it all off, it's glued on.
And leave it off or replace the whole body side trim from the same color Crown Vic, which is what I did.
Or you can paint it over, either way
Problem solved and I think it looks better.
