For cabin noise from the engine?
Firewall in the cabin, under the carpet, that aluminum backed butyl rubber stuff works pretty damn good. Find stuff that's at least 1/8 thick or thicker. If you can find 1/4 inch thick stuff, that would work excellent. It's kinda spendy that thick though. Might be cheaper to double/triple layer the thinner stuff.
Brand options that are known good:
Dynamat
Cascade Audio VMAX (not as thick as some of the Dynamat options, but works well)
FATMAT
BOOM MAT
Thicker is better for noise reduction, but obviously too thick will cause fitment issues with the interior. Working the material as high up the firewall as possible and down under the front seats at least with at least 2 layers over the trans tunnel and firewall to really cut down the noise.
Also there is paint on bed liner with optional sound deadening. I used both bed liner and "that 1/8" stuff" Sly mentioned in the the 89 wagon. It worked well. No fitment issues
03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice 02 SL500 Silver Arrow 08 TC Signature Limited, HID's Mods>06 Mustang Bullet Rims 235/55-17 Z rated BFG G-Force Comp-2 A/S Plus, Addco 1" rear Sway, Posi Carrier, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17 12 Escape Limited V6 AWD, 225/65R17 Vredestein Quatrac Pro, Winter 235/70-16 Conti Viking Contact7 Mods>Beamtech LED headlight bulbs, Husky floor liners
