Originally posted by GM_Guy
View Post
Rimming It
I ran these 17x9 D windows and they fit perfect. I ended up buying some 01-02 LX sport reproduction 17's and will end up running those instead.
Originally posted by pantera77 View PostI ran these 17x9 D windows and they fit perfect. I ended up buying some 01-02 LX sport reproduction 17's and will end up running those instead.
http://www.summitracing.com/parts/crr-3458912
Did yours come with centercaps? And were they all of the same finish. The first time I ordered my set (YEARS back) three came with the same finish inside and out with center caps. The forth had no center cap and was of a different finish all around. They fixed that quickly.~David~
Originally posted by 87gtVIC View PostDid yours come with centercaps? And were they all of the same finish. The first time I ordered my set (YEARS back) three came with the same finish inside and out with center caps. The forth had no center cap and was of a different finish all around. They fixed that quickly.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
yeah. I am looking for the ford caps but they appear to be about 50 a pop. Kinda holding me back.~David~
is there a offset safe zone in how much higher or lower in mm you can go? i have 18x9 deep dish bullit wheels for my 2003 grand marquis, they are 30mm which is 15mm less than the stock. now they fit perfect on the back, but on the front the wheels are mildly duck footed and when i drive there is a slight pull to the right. the stock wheels give me no pull and fit dead straight. is that the offset, was my car possibly hit, or is that the backspacing. the tires dont rub or touch anything around corners or over bumps. id appreciate any thought or opinion.
You should double check clearance on your caliper, my 06 had Mustang California 18" bullitt wheels and I needed a 1/4 " spacer.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
