So I bought a brush guard for $30, but...
Originally posted by ootdega View PostIt has a dent in it. And this dent isn't coming out with any mundane method; the thing is so strong I doubt I could dent it myself with a hammer.
Anyone know how I might repair this?
[ATTACH=CONFIG]41748[/ATTACH][ATTACH=CONFIG]41749[/ATTACH]Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
cut bent section out and weld in equal size steel tubing
The only other way would be to cut the back side of the tubing out, carefully tap it back into shape, and weld shut your access panel. That still probably wouldn't come out quite perfect.86 Lincoln Town Car (Galactica).
Originally posted by Lincolnmania View Postcut bent section out and weld in equal size steel tubingOriginally posted by gadget73 View PostThe only other way would be to cut the back side of the tubing out, carefully tap it back into shape, and weld shut your access panel. That still probably wouldn't come out quite perfect.
However it works out, it should be significantly less expensive than buying a new one for $250.Last edited by ootdega; 01-05-2015, 06:05 PM.89 Grand Marquis GS.
I'd run it as is. but then... beater gonna beat.
Originally posted by ootdega View PostWelding in another section doesn't sound like too big of a problem, but there is the matter of re-finishing the chrome on that section and bending it back into alignment. Those shouldn't be too difficult for someone with the right tools, should it?
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
Welding in a chunk is the easy part, the chrome is hard. Thats the kind of thing you rattle can. Having it re-dipped would probably cost more than new.86 Lincoln Town Car (Galactica).
One possibility that would likely be impractical would be to force a big steel ball through the tube. If the ends of the tube are sealed, then it probably wouldn't be worth opening them up. Other issues would be whether you would be able to restore the original bend in the tube and whether you would be able to avoid damaging the chrome finish.
The ones that I've seen tend to be black. Does it really need to be chrome? If not, then welding in a piece seems to be the way to go.Last edited by IPreferDIY; 01-06-2015, 06:53 PM.
Originally posted by IPreferDIY View PostOne possibility that would likely be impractical would be to force a big steel ball through the tube. If the ends of the tube are sealed, then it probably wouldn't be worth opening them up.
Originally posted by Mainemantom View PostWhat I was thinking was to attach a strip or a round piece of black rubber to the bumper bar. It might look good and cover the damage.
Originally posted by piranah View PostWhat is that a brush guard from?89 Grand Marquis GS.
Well, here's what's on the ends of the tube. This should be really easy to cut off and weld back on. I'll be satisfied if I can just get most of the dent out and get it back in the right shape. The upper tube is loose now, so apparently the bent lower tube was pressing outward on the frame and keeping the upper one secure.
Also included is what it looks like under all that rust.Last edited by ootdega; 01-07-2015, 07:26 AM.89 Grand Marquis GS.
Wear it proudly to show that you're not to be messed with.
If I had a brush guard, I wouldn't worry about chrome. I'd probably spray it with bedliner. I'm with Sly on this one-- beater gonna beat.
1995 Grand Marquis GS - 156k miles, three-tone until I find my paint
1990 Toyota Camry DX - 211k miles, someone else's future barn find
1994 Saturn SW2 wagon - wife's car
Originally posted by SVT98tI'll make it fit.
I own hammers.
