Do not ask me how I know:-(
    For those of you that have utilized the products from Plasti-Dip, listen up!
    They make a product called VLP which is utilized to mend/fix rips and tears in vinyl roofs.
    The product comes in a tube and goes on clear, and is supposed to remain that way............NOT!!!!!!!!!!!!!!
    When the product dries and is subjected to the light of the sun all the areas so "mended" will turn to a brown color, similar to chocolate:-(
    No warning or acknowledgment that this could happen on the descriptive verbiage within the packaging??
    A call to the company with pictures of the damage proved to be a waste of time, as they stated that "we are not aware of any such effect of the sun on our product.........."
    This is a cautionary tale, do not use this product on any vinyl roof exposed to the sun, which would effectively mean you can not use this product!
    that's crap.
    maybe paint the spots with duplicolor to match the vinyl?
      Sly if this was a new top or near new..........I would sue them.
      I just wanted to seal the rips which exposed the padding under it, not have the f-er look like it has top disease!
      that's crap.
        The only fix for a bad vinyl roof is a new vinyl roof. Or no vinyl roof if you're into the poverty model look
          HClick image for larger version
ID:	1276312ere is just one of the pictures I sent to them
            that's what I figured. I'd paint it
              Guess I will have to hunt down sand beige paint from a body shop supply??
                automotivetouchup.com let's you enter your paint code and comes in either spray can or pint/quart/gallon etc.
                I've used it on the nose of my car. (Both the spray can and using the air brush) The paint matching is "acceptable" to me. I wouldn't say it's perfect but looks okay from a little bit of a distance.
                  Wow, thanks!!
