2003 mercury marauder grill?
    i have an 03 marquis and id like the black marauder grill but i dont know if its a direct fit. can anyone help me?
    Direct fit, or just paint yours black
    Sent while running from the cops using Tapatalk
      I believe the header panel is different grand marq vs marauder so grill will not fit unless you change the header.
        Pretty sure it's the exact same, just black.
          I am wrong the grill should fit.
            thanks guys i appreciate it and do the marauder front and rear bumpers fit directly?
              yes. Common swap.
                thanks
                  They'll fit right up there if you can get your hands on them… Those bumpers front and back are getting harder and more expensive to come by with each passing day.
                  2000 Mercury Grand Marquis GS HPP - SOLD
                  Wore out the cam chain tensioners and jumped time at 176k miles.
