i have an 03 marquis and id like the black marauder grill but i dont know if its a direct fit. can anyone help me?
2003 mercury marauder grill?
I believe the header panel is different grand marq vs marauder so grill will not fit unless you change the header.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Pretty sure it's the exact same, just black.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
I am wrong the grill should fit.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
yes. Common swap.
They'll fit right up there if you can get your hands on them… Those bumpers front and back are getting harder and more expensive to come by with each passing day.
2000 Mercury Grand Marquis GS HPP - SOLD
Wore out the cam chain tensioners and jumped time at 176k miles.
