curious of the offset on my 2003 marquis
    i dont have jackstands or a jack so i cant really take the rim off myself and measure it. i also went to tire kingdom and the person behind the counter pretty much told me to do it myself, which i wouldnt have went to a service center if i knew they were going to tell me that. im curious of the offset in mm, if anyone can help me out that would be great. thanks.
    About +45mm
      thank you, the rep at tire kingdom told me it was probably a negative offset so im glad i didnt listen to him.
        Easier to look up 2005 Mustang in case you forget or need them to look it up again, same offset in stock form
          why is it that the aftermarket rims for the 2005 mustang range from about 17-30". would the mustang owner purchasing it need to get spacers?
