I (mostly)finished the halo upgrade and tested out the bulbs I have.
First I had to get new covers for the halos, the stock ones could be modified(I did one) but it looks pretty bad since you lose the ridges that you can see when the light is off, you could recreate them but I don't see going through and getting that right. The halos on the lights from Dapper are meant to hold 2 little LEDs, the COB halo I am using is about 1mm thick so you need about 1mm under the halo for these to fit.
This is stock next to modified stock.
I found halo covers on ebay and bought them, they are hollow in the middle.
If the COB halo had fit in that open area, that would have been great, but it didn't.
I trimmed the sides off the covers to make them fit right but now they are in and look ok.
