Modern headlights for boxes
    Yea, that's what I noticed as well. They just have 2 diodes pointing in opposite directions. Not nearly enough to light up the whole ring evenly.
      I got mine to light up for a few seconds. Found a fuse attached to the relay harness that blew. It was really hidden. Replaced and they lit up. Now they dont, again.
      1990 Colony Park, with HO swap.
      Previously:
      1990 Lincoln Town Car Cartier.
      88 CVLX
      01 Marquis
        Sounds like you got a short somewhere causing it to blow fuses.
          Wasnt a fuse. Was a wiring issue again. They work, for now. gonna test it out driving home from work tonight. At least my brights work now so i have those if needed.
          Previously:
          88 CVLX
          01 Marquis
            With the previous wiring issue, you may have damaged some wiring.
              Wires were not touched from previous issue. Just repinned the connectors.
              Previously:
              88 CVLX
              01 Marquis
                Guess which one is stock.
                  that's impressive. What were the changes?
                    Nice! What halo kit did you get?
                      Ebay, Chinese 70mm COB halo, I think 80 LED. The back of the halo cover needs to be trimmed down for them to sit flush, there are fins on the back(to spread the light off the little LEDs it comes with) and just cutting those off should do it
                      Sent from my iPad using Tapatalk
                        that is impressive.
                            Is the stock LED ring removable off the projector or is it glued on there?
                              3 tabs hold it on, just push them in and off it comes.
                              The 2 LEDs come out through a hole in the chrome ring, nothing is glued down.
                                Ah ok, nice. Thanks for the info. Just ordered some halos.
