Doors slightly crooked on 1990 MGM
    I have messed with them quite a bit trying to line them up correctly, but I am still getting that annoying grind, hurting my beautiful door and car body. Anyone dealt with this before?
    1987 Grand Marquis LS (GONE!)
    1990 Grand Marquis GS
    I like to go fast
    Hinges sagging???
      I was thinking...is it possible my hinges are just no good?
      Sent from my SGH-T889 using Tapatalk
      I like to go fast
        yeah that's pretty common. If you lift up hard with the door open is there play/movement?
          Yes, and when I lift it up while opening it i don't get the grinding as well. Where could I get some hinges, aside from the junk yard?
          I like to go fast
            I got a brandy new hinge from someone here (lower driver side) for my Lincoln (uses the same as the fronts on boxes) and it sorted the sagging issue. Might have been WagonMan. I don't have the PMs any more, otherwise I would check.
              To the ebaymobile!
              I like to go fast
                You can either put in new pins and bushings (sold at your friendly neighborhood autoparts store)
                This is a must-see site for fans of American luxury hot rods. Message forums, tech advice, news, and automotive performance links are offered for Lincoln Mark VIII and Mark VII, Lincoln LS, Town Car, Continental, Navigator, Aviator, Zephyr, MKR, MKS, MKZ and more.
                or you can find a junkyard hinge that looks in good shape. I went that route since one of them was bent. A third option could be simply realigning the doors. I had a body shop do mine for around $15 per door. They also put shims under the front hinges and now they close just fine.
                  I almost feel like I'd rather pay $15 / door than deal with the headache
                  I like to go fast
                    Doubt you may be able to get someone to do them for $15 a door but if you can I would certainly do so!
                      if I could pay someone $15 per door to rebuild or replace the hinges, I would do it in a minute. It takes me longer than $15 to unbolt the things.
                        Agreed.
                        I like to go fast
