Water Leak...
    Water Leak...
    I have a water leak coming in where the black plastic housing for the heater core is. It loves to pool on the floor boards under my rubber flooring. MY question is, do I have to basically go through the procedure of taking the heater core out to seal it, or is there a way to seal the whole thing without going through the trouble?
    -Phil
    Take that screen off by the windshield on the passenger side and make sure it's not full of crap down there.
      This is likely due to the heater core being replaced at some point. Best thing to do is, remove the vent screen by the windshield then, seal it up with some good sealer/caulking. It should be good then. Just be carefull when washing your car that, you dont point the water directly into the screen.
        Only place it could be coming through is the air intake vent by the windshield, or maybe if water is running down the firewall, it might be coming in around the bolts that hold the heater core box in place. The bottom of that air intake box is supposed to have a drain in it, and its usually packed full of crud. Check that first.
          Thanks guys, I put a tarp over the windshield area of the car during this massive rainstorm, I'm tired of ripping the floor up to dry it out. I'll check all those places. The heater core is original (amazingly, and the cooling system is pristine). I really want to nip this in the bud. I also have a small leak coming from around the windshield, but I intend to take the trim off and seal it with some black silicone.
          -Phil
            yeah dont let that go too far. If you've not seen pictures of the roof on my car, dig them up and then you'll be more motivated to fix your leaks.
              Found 2 leaking grommets, one coming in from the door into the lower a pillar area, and the other in the firewall leaking water. Also there is a smaller slower leaking coming in the heater box. (see Pic) I'm going to try to get to the nut on the other side and tight it, as well as apply black RTV to the grommets, and the bottom of that intake screen
              -Phil
                if you have water coming into the heater box like that, I'd have to believe the drain isn't draining.
                  It is, quite well. I ran a hose directly down in there and felt around with my hand to make sure. It was a very large volume of water in short time haha
                  -Phil
                    Well it's raining today, no water on my floor! WOO!
                    -Phil
                      w00t!
