Hello all! I'm the new owner of a repainted/new top TC. The previous owner, my Mom, took very good care of it. It's got about 85k on it and that is mostly highway miles.
After noticing the headlights being a bit dim I decided to start upgrading them. I installed 4 Autopal housings and 4 Hella 100/55 watt H4's. I tested the lighting and observed that there was NO WAY the stock lighting circuit would hold up to all the wattage I was putting thru it. I started the wiring upgrade and currently have the low beam circuit complete. I'll be doing the high beams as time permits. To keep things safe the high beams have been disconnected. I decided to use two relays for the high beams due to high amp draw.
Sent from my VS980 4G using Tapatalk
