I've got a 1985 country squire, I removed the inside door panels to get the exterior door handles off. Come to find out they a riveted in. Has anyone drilled them out and replaced them with bolts? I'm getting ready to paint this thing and I need to finish removing the old vinyl around the handles.
Door Handle Removal
Yes, a few members have replaced the door handles and used bolts, of course you can also use rivets again if you are anal about originality... why is there vinyl around the exterior door handles though??-Phil
wood-grain vinyl... I think it even goes in behind the handle as well.
Originally posted by sly View Postwood-grain vinyl... I think it even goes in behind the handle as well.Vic
Get a punch and tap out the center then drill it out. Helps to have a buddy hold the handle away from the drill bit.~David~
