Originally posted by 87gtVIC
View Post
Silvo
One uses a clay bar to remove impurities in the surface of the paint like baked on bugs, sap, debris etc etc. Ensures a nice clean and baby bottom smooth surface for your wax to be applied onto.
Clay bar is just what it sounds like. A Bar of clay. Lube in the form of detailing spray is applied to the clay and surface of the vehicle. Always work in small sections and do not run the clay dry. Always keep it gliding on the surface. Every so often kneed the clay to reveal unsoiled portions.~David~
The only way you screw up is by dropping the clay.~David~
I clay bar my cat, then shine him up w/Brasso...
brass monkey?
Originally posted by mitymerc View PostI clay bar my cat, then shine him up w/Brasso...
Originally posted by sly View Postbrass monkey?
As long as one's cat is not aluminum, Brasso works fine. It even smells like cat pee, so its a soothing scent for them.86 Lincoln Town Car (Galactica).
Thank you for noticing, though if you've ever used Brasso and/or read the label you'd understand. It is not suitable for aluminum, and it smells rather like cat piss thanks to the ammonia content, which is actually why its no good on aluminum.86 Lincoln Town Car (Galactica).
Originally posted by Mike_Windsor View PostOh.
Well I'm strange too apparently.
