Ok..... my back left door (drive side).... creaks and scrapes against my driver side door and bangs against it when i open it... and my passenger door creaks when i open it. What do i do to fix that?
Body (89 Crown Vic)
Body (89 Crown Vic)
1989 LTD Crown Victoria LX.
-3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
4 Door Muscle
SupermotorsTags: None
Odds are your hinge pins, and or the bushings around them are worn. Check em by opening the door, then trying to lift the door at the end. If you can wiggle the door up and down, and you can see play in the hingepins, theyre shot.1988 Ford Mustang coupe: 4cyl conversion, 5spd, 600cfm holley, roller rockers, headers, 2.5\" mac exhaust, alum. driveshaft, HD clutch, poor mans posi, blah blah blah.....
1993 Sable: Ultra Beater
