color matching on a white 1989 LTC
    Ok, I need your help guys!
    I am trying to touch up the paint on my 1989 LTC that is white. I went to the parts store and picked up ford....NG FM 229 oxford white and the GM ......NG GM 433 Bright white, I don't know what color to get. This is the closest colors I can get, does anybody know what is the exact color code to get for the touch up paint???
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    Color code should be on the door (driver's door) label. The code equals the paint name which can be found either in the store or online.
      Really, the color code is there on the door?
      The auto parts stores computers can't go back that far so i think im SOL
        Most white box panthers I have seen, are oxford white. Its not pure white, depending on the year. What is the two digit code from the door?
          Then look it up online. There is a company, in New Orleans, that makes all the older colors by the spray can or bottle if you need it.
            for most colors you are correct, most parts stores computer and print info doesn't go back that far , however , it goes by the paint code , and most whites and blacks have been the same for DECADES , that being said , if it is oxford white , that color may have been used for the last 30 years and should have used the same paint code , so , if your paint code matches that color it should be the same(nnot taking into account sun fade and age discoloration)
              of course
              sun takes a toll, i accept that
              so i should look on the door for this color code, NG FM 229???
                Its a two digit code. If you can read your door tag and get the code, I may be able to get you the paint type. And like said, most base paints were used for years but, the codes kept changing. Oxford white in '81 will have a different code than '88 but, may be the exact same white.
                  so would I take the door code to the dealer to get the color name?
                    Nope, I have some factory manuals that list the codes. Is your code 9L under the "exterior paint" part? If so, its oxford white.
                      ok ill check tomorow morning, thanks for the 411!
                        Your welcome mang.
                          When I was buying paint at NAPA last year, the guy took a mobile scan of my car. The scanner was plugged into a computer and the factory color was soon found.
                          '79 Continental Town Car
                          '90 Crown Victoria LTD
                          '94 Crown Victoria
                            I just looked at my car. It is a 9L on the door, which I am guessing is Oxford White!
                              That's what shows up online!
