there is no need for custom ones. i just picked a set of 4 2" off ebay for $111 and some change. if you use common sense, make sure you got a clean flat surface, and torque the lug evenly (skipping every other lug) then youll be fine. i cannot imagine a company making faulty spacers granted that could cause a serious accident and huge problems for them.
18" mustang bullitt wheels
Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
Originally posted by hemihotrod402 View PostYou don't need spacers for a backspacing that it less than stock, that would just push the wheels out more. You only need spacers for wheels that have higher than stock back spacing, such as the mentioned Bullitts, which have 6 inch backspacing IIRCCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
They must be hubcentric as well.
03 Mercury Marauder- 63k
Originally posted by SVT98t View PostIt wouldn't hurt. I switched from 21mm to 19mm because there was a slight clearance issue while securing the spacer to the axle.
Also, this shop is trying to get your money.
I just find it odd because the same spacers for your 2000 also includes all Panthers from, what, 1980? until 2002. And some Jeeps also use the same spacers because a lot of them use the 8.8 rear axles. So there is, in essence, millions of vehicles that would use these spacers.
I find as long as they use T-6064 billet aluminum, there shouldn't be any problem.
I just couldn't justify $325 in spacers.
I feel you bro but with the custom made spacers no vibration this guy is convinced that there will be vibration . Let me mention that this guys deals with mostly high end and high performance car every time I go there there's Porsches bmw m3s I seen a Lamborghini and a ford gt so maybe anyways it's too late already paid for them I asked if I could cancel it and they said it was too late ill kno next time.
quick question.. what does hub centric mean?Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
nevermind.. found it.. and that was a long ass explanation.. glad i didnt make one of you guys explain it hahahaCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Ya. That's important shizzle too.
I hope they work for you mang!!!
eh... if that description was accurate, the rims on the Merc are lug centric. same as the new ones for the townyCharlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
Any suggestion on what to do with the rubbing? Rides fine when I'm alone but if I have 1 or more passengers when I'm on the high way and giver over slopes the car rocks and drops and rubs real hard. My suspension is real loose and smooth should I just roll or cut the fenders or should I upgrade my suspension to make it stiff or should I do both I wanted to drop it a little but I think it's not a good idea now that I have this running issue. Cab u guys give me some suggestions
rolling the lip up tight on the fender will probably be the first and possibly last step. the trim may not like it though.
How big are the spacers?
