About Undercoating
    About Undercoating
    Was thinking that I should add "undercoating" to the list of seasonal maintenance things to do for my car.
    What is everyone's opinion on it?
    Do it. The stickier the stuff the better, and the more knooks and crannies you get it in (without blocking drain holes) the better. the DYI option for you would be asphalt undercoating (not the rubberized stuff unless you remove alllll dirt and rust before application) from Canadian Tire. The let-an-expert-do-it would be RustCheck or Krown shops.
    The first option will cost you 20-50 in cans, depending on how obsessive you are with it, and the latter is more like 100-250 depending on how good a job you have done.
      I was thinking it should get done just to preserve the undercarriage and such.
        If there's already serious rust, undercoating is a waste of time/money.
        '79 Continental Town Car
        '90 Crown Victoria LTD
        '94 Crown Victoria
          There isn't a whole lot of it, actually.
            I was wondering this myself as it is on my list of things to do. I have a layer of surface rust but nothing very deep or penetrating. I've heard someone mention por-15 and read a lot of good reviews on it.
              por-15 is great, but generally something you have to apply for yourself (at probably 100 bucks minimum for the paint alone) or pay out the nose for someone to do.
              IMO, undercoating IS worth it even if there is surface rust already, it just depends on the type of undercoating. The truck bedliner type stuff that is basically a rubbery paint will just trap rust, but stuff that is a thick oil/tar type consistency will afford you some protection. Of course best practice is ALWAYS to remove rust as opposed to covering it up, but...
                Do it! I undercoat my wagon twice a year. The white and liquid death they put on the roads here, will eat you car if you dont do it. My wagon is originally from alberta and is mint on the under side but, has some minor surface rust too. The rustproofing has preserved this car and stoped the rust from spreading. It also keeps the salt from getting to the existing rust and making it worse. I use krown rust proofing. I dont know about other locations but, the guys I sue are pretty good. They do a good job. And if you want some special areas sprayed extra, they wont hesitate to do it. Also, stay away from dripless undercoating. Its an imitator lol
                  Alberta doesn't use salt when laying sand/dirt on the roads, so cars last longer here than in Ontario.
                  Anyways, how much does it cost for rust removal? ._.
                    Depends on the rust and the shop. For a few minor little surface rust bits on seams? maybe a couple hundred. If you've got holes and major rot, the sky is the limit.
                      im contemplating an oil mixture of some sort. a real thick sloppy one.
                      suck to work on but it'll never rust.
                        Sand some times can be just as bad. It just takes longer to do its thing. The bottom of the rear quarters were rotton from sand. When prepping the body work, there was alot that came out. The sand gets into tight areas and holds the moisture, then the proccess slowly starts. But yes, sand is better than salt.
                        I pay around $120 for a full spray. But, since your not exposed to salt, you could get away with a spray every second year. Considering you give the underside a good wash in the spring. And good mudflaps keep the high pressure tire wash, from washing the oil off of rocker panels and such.
                            Get it oil undercoated or don't waste your money. I have my winter wagon oiled every year, runs me about $110.
                            Don't bother with rubber undercoating unless you don't plan on driving your car in the winter. I've tried POR-15, many types of rubberized undercoating, ect... Buffalo winters just laugh at it and come spring it's already rusted again. Oil based undercoating is the only thing that seems to work around here.
                              Exactly. Everytime I see these undercoating products, I LOL. Oil is the only thing that puts up a fight. Like they say, if it dont drip, it wont work. The oil the guys on my car spreads 10X than tranny oil.
