wagon spare tire well filled with water?
    Hey!
    I was surprised a bit today when I noticed a puddle by the RR of my 1990 wagon, take a closer look, and it's running in a fine stream from the spare tire well.
    It's clean and pure looking, hoping to god there's no rust created yet.
    I had the car professionally undercoated this winter, the same stuff they use for the toyota tundra recalls (severe frame rust issues on them).
    I suspect it sealed something up.
    a) how does the water get IN in the first place? It's never been a flood car, sitting in water that went up to the well!
    b) is the fix to take a drill bit and drill, and widen the existing hole or punch new ones so that no water is trapped inside?
    My door panels are also still rust free, for now, even at the bottom seam.
    Any other measures I should take now? e.g., drilling holes in the bottom of my door panels too?
    thanks!
    -Bernard
    clean the existing hole out. Its probably clogged with crap. I'd also be looking around that big side glass. Betcha you have a leak in the glass to body seal.
    The doors have drains in them already, but you should make sure they are clean so they drain properly. The ones in my Lincoln were so clogged when I got it that the first time I shut the door in the rain, I heard the door slosh.
      Check the foam seal on the back side of the tailite. I had one of mine leak.
      79 Bronco XLT 129000kms
      88 LTD Crown Victoria wagon LX 223000kms
      03 Expedition XLT 256000kms
      06 Escape XLT 188000kms
      09 Focus SE 132000kms
      13Escape SEL 63000kms
