Push Bar
    Push Bar
    seems they dont make them for the marquis. only vic now with the cars being the same exept for the bumper plastic could i get one for a vic and bolt it on the marquis ? if so what would be the best year ?
    01 grand marquis ls all stock for now
    none of them "bolt up". You have to cut holes in the bumper cover for a couple of bars to go through or it'll bounce around like a superball. The same model year vic bar should fit, you'll just have to figure out the locations to cut through the plastic on your own.
      Thanks for the info i knew i had to cut the holes that doesn't bother me i just wanted to be sure the frame locations were the same which i assumed they were. i just really like the looks of the push bar plan on going with the setina
        Hopefully you won't have to cut the grill itself. I'm not sure exactly where they mount on whales, and I'm not sure how much lower the mercury grill dips than the ford one.
          we built one for a customers wagon......used a pickup push bar and side bars from a nissan pathfinder........deer fly over the car when you hit them now!
            that bar is the bar of epicness. Ivan should make a few more and sell them
              they do make a no cut version of the go rhino that you do not need to modify the bumper cover for, just an idea
              -Dave
              2004 CVPI aka Guinevere
              Courtesy of 2004_P71
              TR3650 5 speed manual with hurst short throw shifter, 4.10 trac-lok, heinous control arms, Pioneer AVIC-X930BT w/Nav Head unit, Pioneer speakers all around, Pioneer Amp with 2 12" Kickers in the trunk. Marauder Spoiler, white honeycomb grill and rear fascia. Tinted Lights all around.
              Thank you Pier.
                I'd like to see a whale Marquis with a push bar. I think that would be epic.
                  wouldn't mind seeing some pics of this bar
                  staying away from the go rhino as i heard there not very good the no cut model esp. guess if u hit something the way it mounts it breaks something on the car
