LED turn signal flashing rapidly (i have seached this before posting)
    I know Im a noob here!
    I did research other threads about this topic......
    I did replace the turn signals with led lights......and I know I need a flasher relay or heavy duty type
    But not sure where to put it, or where to find the old one...looked under the fuse box,
    and relay housing next to my battery.
    Its for a 2004 grand marquis...any could help me find it, or have a part number?
    ....btw...this place is awesome
    1979 Marquis creamy goodness
    .....the cornering lamp light...is now out....I tested it before I replaced the turn siganl light
      You don't have a flasher, you have a LCM (lighting control module) and they do not like LEDs. You have to wire in resistors to your circuits or buy the more expensive "CANBUS error-free" style replacement LED bulbs.
        thanks!
          Well doesn't that bite the big one.
          Pete
            Pete
            pete, what are you reffering to???
              I found the module...under the stearing colum...where the "click" is coming from.
              Just bought all cambus bulbs
              The Autolumination provides Canbus Bulb Out Warning Fix Led Bulbs for BMW, Audi, Dodge, Chrysler, Mercedes, VW, Volvo.
                Hhhmmmm.. that site says that bulb-out and turn signal issues may not be the same problem... but I bet you are fine. It sounds like these satisfy the resistance values for the European warning systems, and I don't see why that wouldn't satisfy the LCM. Let us know how the bulbs look, especially in direct sunlight. I'm curious how the latest design ones work, and those look like they are it. They are evolving very fast, thats why I haven't updated mine yet...! lol
                  Will do.
                  Since my turn signal is flashing like crazy (for the time being)....this wont damage the LCM?
                    nah... the light load that causes the fast flash won't hurt it. it's typically the long term regular loading that ends up burning up the relays in the LCM. Non-replaceable relays (they're soldered to the board... gotta desolder them and run wire harnesses if you ever replace them instead of replacing the whole module) and expensive module makes for many DIY fixes.
                      Got it...worse case situation, I could go here:
                      pop a new one in...my fabrication skills are still in the making
                        Well 85Crown, it turns out your half right.
                        I put the Cambus blubs throught....whats strange, is that when my head lights are on, my passagner side turn siganl
                        blinks at the normal pace.
                        However,My drivers side is rapid blinking
                        When my headlights are off, they both blink rapidly....
                        I will post a pic soon
                          ok... that is weird. I'm thinking multifunction switch.
                            I have replaced ever bulb with the Cambus LEDs.....now my turn signal light would flasH AT ALL!
                            the fix for this is supposedly here....
                            Im starting to hate LEDS....any tips?
                              I'm out of ideas due to the LCM issue.
