Originally posted by TomO
View Post
Box Body Roof Modification Questions
Originally posted by sxcpotatoes View PostAre there any pictures around of a slicktop box Merc? The vinyl is cracked to hell and back on one of my '91's (1980c10's old purple-rimmed one I'm putting back together).'79 Continental Town Car
'90 Crown Victoria LTD
'94 Crown Victoria
Originally posted by 86VickyLX View PostYou have full vinyl or half vinyl?88 Town Car (wrecked, for sale)
Originally posted by 88Vic View PostHalf vinyl, which is kinda the reason why I don't want it. It's not in bad shape yet, just need to coat it and keep it clean. I'm not a fan of the half vinyl, rather it be all or none and since doing full isn't an option since that'd be even more time and money, i'd rather get rid of all of it and not worry about the vinyl cracking. But since I have the smaller window that means I have the fiberglass shell so it'll probably never look right if I slicktop it.
Originally posted by 86VickyLX View PostBelieve it or not, a full vinyl top on a Towncar would be cheaper than a half vinyl top.
Originally posted by mercurygm88 View PostI always thought it was strange that the base model towncars came with a full vinyl top. I did see a box grand marquis in a parking lot yesterday it was black with a black full cloth roof and no coach lights. I always thought that was something only available on towncars.
I'm not sure why the police cars all had painted roofs. Probably for durability and because of the perception (although not true) that vinyl tops were more expensive. Just my guess, again.
I noticed on the aeros, they figured out how to put some sort of plastic filler strip in the weld seams. This eliminates both the old filling procedure and the cost of vinyl.
It is, but the extra structure is the fiberglass shell, kinda like a hacked off truck topper. Now, since you want to do a slick top, the $20,000 question is:What sheet metal got hacked away, if any, to add a coach roof. Did they just puff out the trim and cover the standard window opening edge, or did they take a saw to it and hack away the lip... (Didn't somebody here remove a rear window shell at one time?)
Heres some shots from stap '11.
Mine is the half roof on a 1987 GM. Almost mint condition except one or two little "nicks". Now if I could find a good conditioner I'd be set. So far, EVERYTHING has come off with the rain and stained the body. 303 also! Anybody got a good candidate???
303 does run a bit with the rain. Before I used to just spray the 303 on the roof and wipe it around with a microfiber cloth. Now I do the same but buff everything after with a microfiber cloth and I get much much much less stainage.
I will continue using.~David~
Originally posted by GM_Guy View Post
lie if you have too.Last edited by bigbeigeboat; 02-26-2012, 05:55 PM.You know the car runs well when the only things left to work on are the rear door cigarette lighters.
Originally posted by 87gtVIC View Post303 does run a bit with the rain. Before I used to just spray the 303 on the roof and wipe it around with a microfiber cloth. Now I do the same but buff everything after with a microfiber cloth and I get much much much less stainage.
Originally posted by miamibob View PostMine is the half roof on a 1987 GM. Almost mint condition except one or two little "nicks". Now if I could find a good conditioner I'd be set. So far, EVERYTHING has come off with the rain and stained the body. 303 also! Anybody got a good candidate???
anywho, looks like that ford just makes a frame, to fit in the exiting window area. its cheaper for for this way. so i would say, its only nesassary to fill the body seams and get new rear glass. but damn, i dident relize how much i liked the formal coach roof. would have been bad ass, if offered on two-door models.
Originally posted by marquisman View Posti use this special, french shit, that goes on creamy, yet dries. it dont dry out, but dont wash off either. see if you can look it up, i bought it from a guy at the show. he says all the hi end car guys use it. its called URAD leather cream. the container has a web site too. www.selectmarketinginc.com , its used for leather(man made and natural), rubber and vinyl. and its made in a italy....some of a beech!
