Originally posted by TomO
View Post
Box Body Roof Modification Questions
I'm going to try to post two pictures. One is a right side view of a coach roof and the other is a right side view of a non-coach roof. I've drawn red lines on the perimeter of the C-pillar on each photo. If you compare the shape of the C-pillars, you can see that they are different. The top of the coach roof is longer and the rear window is more vertical than the non-coach roof.
It would still look better than a vinyl roof in my opinion, mine I think is starting to crack since I don't have a garage to store my car in an most of the time it sits in the sun.88 Town Car (wrecked, for sale)
Originally posted by TomO View PostI'm going to try to post two pictures. One is a right side view of a coach roof and the other is a right side view of a non-coach roof. I've drawn red lines on the perimeter of the C-pillar on each photo. If you compare the shape of the C-pillars, you can see that they are different. The top of the coach roof is longer and the rear window is more vertical than the non-coach roof.
Originally posted by mercurygm88 View PostIf I remember I'll go out and measure mine tomorrow but I can tell you for sure that it does taper smaller towards the top.
That tells me that since the bottom of the rear window in both coach and non-coach is in the same spot (right next to the trunk opening) the upper part of the coach roof must be longer than the non-coach roof. So, there must be some sort of structure that is added on to the standard roof to make it longer.
I have a vague recollection of seeing a coach roof car with the vinyl removed and you could see that there was some sort of white fiberglass or plastic piece attached to the standard roof that makes the upper rear edge of the coach roof extend rearward for at least several inches.
Originally posted by 88Vic View PostIt would still look better than a vinyl roof in my opinion, mine I think is starting to crack since I don't have a garage to store my car in an most of the time it sits in the sun.
That, of course is the cheap and dirty way. You can also fill them, but then you'd also have to sand and repaint most of the roof.
Originally posted by mercurygm88 View PostI like my vinyl top and after 24 years its still like new albeit a little dirty. I go over it once a month in the warmer weather with a vinyl protectant/conditioner. Regardless of the fact that I am a full grown man if it ever starts to crack I will cry.
So, yes, it appears that regular application of conditioner will really help preserve the vinyl.
Maybe call a glass shop and ask?
Jay03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostMaybe call a glass shop and ask?
Jay
I'm mainly wondering if it's possible to do the conversion from coach roof to non coach roof, and if so, what it entails.
If it's possible to get a coach roof to where it's the same as a standard rear window, then it seems like a glass shop should theoretically be able to install a gasket and window glass. But, I don't know if the standard body is cut or somehow permanently modified when the coach roof is installed.
Anyhow, maybe I will call a glass shop or two and ask -- I guess it couldn't hurt.
Originally posted by TomO View PostI think it depends on what you're looking for. If you have basic handiwork skills you could do a basic slicktop conversion yourself. I did one on my '89 Grand Marquis, but it was just a standard, all metal roof under the vinyl. Most cars actually have a nice coat of paint under the vinyl. The trick is (after removing the vinyl) to get all the glue off. I did it using a heat gun and plastic putty knife to get most of it off, then use acetone to get the rest off. Then you might want to fill the roof weld seams. I used lots of layers of fiberglass mat to fill mine, followed with bondo filler. You'll also need to fill the holes in the roof if you remove the trim at the front of the vinyl. There are lots of ways to do this. The simplest way is to get some small rubber expandable plugs. They look like an upside down top hat and they have a threaded insert in them. You put a small machine screw in the insert and when you tighten it, the plug expands. You may have to drill the hole out a bit. Go with the smallest plugs that will still fit. That way they won't be very noticeable.
That, of course is the cheap and dirty way. You can also fill them, but then you'd also have to sand and repaint most of the roof.88 Town Car (wrecked, for sale)
Originally posted by 88Vic View PostThe problem is that I have a Town Car, so mine has the fiberglass shell and a smaller rear window. I'd have to do all that plus install a completely different window. I can do a lot of automotive work myself but I have no bodywork experience at all, and i'm not about to practice on my Lincoln (I can get an old minivan or accord for that). I need to really inspect how bad it is, I may be able to save it by using a vinyl protector, it's not what I ultimately want but it would save me a ton of trouble. I could go the route of dying the roof to match whatever paint I choose, although the vinyl does have to come off to get the rear window out to get it re-tinted, so it's all still up in the air.
Mine was in good shape, but I didn't really care about keeping it all original. I even considered the possibility of removing my vinyl top and then rolling on some sort of thick epoxy type paint with a heavy napped roller to make it look like vinyl. Then, I ended up just taking the vinyl off and doing a "poor man's" slick top conversion.
as far as towncars are concerned there were two different options, one had a fiberglass shell, and then there is the reguar roof, which i have and have converted over for a slicktop, its one of those you either love it or hate it things really, i will be finishing up my slicktop project this summer i hope.89 townie, mild exhuast up grades, soon to have loud ass stereo....
