So once in a great while (it used to be anyway) I would get some water in the trunk, I figured it must be from heavy rain and a worn seal and thought nothing more of it after I shop vacuumed it up and let everything dry. Well now it is happening every time it rains. So I dissected the trunk lining looking for my answer after I examined the seal and ran a garden hose stream over the rear window with the trunk open. The seal was fine and the lip around the seal is all intact. So I thought maybe it was the tail light seals being worn, sprayed some water over them and ... nope, nothing coming out by the light sockets. Well I must have had about 4-5 gallons of water in the trunk this time, and it was also down in between the quarter panels. The thing that pisses me off (and yes its my fault) is that I never checked there when I first had this problem, so it could have been there for a few years honestly, slowly destroying the body work i did three years ago. Anyway I discovered the leak is happening mostly where the seams of the trunk bottom meet the rear panel of the car (the panel with the tail lights in it) the factory either didn't do an appropriate job sealing this area, or it has fatigued over time and split. It drips in from here after the water runs through the water trough around the trunk. Also all around the tail light bolts there is very minor seepage. Im guessing this may have been a factory error because when I bought the car the rear quarters were completely gone, and had holes in them that were pretty large, and where there wasn't a hole the metal was just too thin to do anything with, this was odd only because the car had 36k on it when I purchased it and it had rotted sitting in a barn? its not like it was left in a snowbank outside.
Anyway what should I use to seal this? I can silicone the bolts for the tail lights, but the areas that were factory sealed with that yellow goop are much larger than a silicone gun would be practical for. Is any of that spray rubber seal any good? Unfortunately this has started rotting the new quarter panels from the inside out, fortunately the trunk floor is unharmed. I also don't have a garage to keep my car in at the moment, so any suggestions on products that may solve this issue would be very helpful.
As always thanks again, and make sure to check your trunks out.
-Jr
-Jr
