1992 CVLX. 5.0 HO/GT40P/T5/3.73/trak-lok with bolt ons. 02 front CVPI setup, rear HPP setup, CVPI shocks around, F250 radiator, e-fans, and the power of 3G. 15.92@89mph, 2.4 60', 4700' elevation (5500' DA) with 3.08 open rear and the old oil chugging 289. RIP.
lots of purple power in a cheap garden sprayer followed by the pressure washer, repeat as needed
I covered the alternator, distributor, original fender mounted relays as well as the salt and pepper shaker looking electrical connections when I spray down the bay with some heavily diluted simple green. I use a brush to get in all the tight areas and a rag to get all the large spots. Once I am happy with the cleaning I hose it down again then remove all the bags and dry everything with another rag. If I ever do it again I would be sure to spray down all the plastic pieces with 303 to give them that new look. Should brighten up the bay a bunch. I usually hit all electrical connections with wd40 to get all the water out as my final step and spray the battery terminals with some corrosion protection spray as well.
I've never covered any of my stuff. The only time I had problems with waster was following a rain storm. I had water in the ECM connector. Never had issues with water from the pressure washer. You figure it out, because I sure can't.
Obviously I'm not running the SEFI stuff most people have, but I've also basically hosed down the entire engine, both running and not running (but always hot) and never had any running issues.
