what hoods interchange?
    ok my local junk yards comp said only a 80-83 mark or 80-85 town car hood will fit on my mark but i just found a hood for sale that says 80-89 town car.........so will a 89 town car hood fit on my 83 mark?
    1979 lincoln versailis, ford test ordered car, factory floor shift with bucket seats.
    1983 lincoln mark VI, all factory
    2015 Mustang GT 50yrs SHERROD, 6 speed 302, track pack, premium package, Custom JL sound system.
    im pretty sure 1980-89 lincoln hoods are all the same. only thing to make em different? either its an aluminum or steel hood.
      80-89 Towncar and 80-83 Mark VI fit. Only difference is steel vs aluminum. I like aluminum for its drastically reduced weight and the lack of dancing on the highway, but they corrode on the inside. Check around the latch for rot problems. Much more difficult to repair the aluminum hoods if they are rotted.
      Also, if you go with a steel hood, you will need a passenger side hinge so you have both hood shocks, and you'll need a pair of shocks specified for a steel hood. They are different than the dual shock aluminum hoods. Ditto if you're going from steel to aluminum. Steel shocks will cause the aluminum hood to bend around the hinges.
