front door repair
    when it gets warmer im gonna paint all door jams and all inside of doors.
      Looking pretty nice. Dumb question, though - how do you know the contours will line up properly after it's installed?
        didnt change contours just fixed rust and took moulding clip studs off so it should line up properly
          Ah. I assumed it'd end up a different shape any time filling and sanding is done, unless care is taken to block-sand the entire car or else to block-sand it to match the existing doors and fenders.
            Looks like a brand new door and I am not kidding. I have one in my basement that look just like it.
              did seam sealer on door when it dries gonna paint and start on puttig stuuf back on and the door panel?
                Looks really good man. What are you planning to use to paint it?
                  not sure single stage or base coat/clear? kirker,ppg,Crossfire, Omni, Nason, Limco,U-Tech or Valspar.how much money will tell me.
                    got window regulator and motor in and window guide rod.i forgot where these arm rest hold down go anybody have a picture of door panel off
                      put Sound Deadening on door and started cleaning up door jams
                        You did the sound deadening very nice. I hope the door penal goes back on easy for you. I was thinking about doing it like that when I had my car apart but didnt want to risk having the door panel fight me when it came time to install it.
                          with the sound deadening the door panel should go back on easy i hope?.got more work on door jams and did some touch up on lower rocker panel. more pics
                            Looks like you have a nice empty area to work in.
                              Those pics are annoying. Wish I were in a position to start working on my wagon again.
                              Otherwise,
                                got paint on inside door now gonna do jams when weather is better
