Grand marquis bodywork ?'s
    I'm new here and i did not find anything related to this post. I have a 2002 grand marq the was just in a accident. I was wonder could i use a crown vic for replacement parts if so what year? And what year grand marq could I use for replacement parts. I have some pic so u can see the damage.
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
    A MAN THAT STANDS FOR NOTHING WILL FALL FOR ANYTHING!!!
    crown victoria doors are the same.....98+ for sure, 92-97 doors may fit, i do not know for sure tho
      thanks so what would i do about the interior part of the door could that still b reused.
        1994 MGM GS Montigua
        2002 Mustang GT Coupe
          she looks kinda tweaked.
          what happened?
            ooh, that looks bad. Often when they get T boned like that, the frame is bent. At a minimum, the B pillar is bent.
              This guy tried to jump the light from like 20 feet behind the light as i was turning i got t boned now we have to go threw the legal stuff his insurance said that it was my fault. I can't wait any longer and i need to get my car fixed.
                unless you can fix it yourself or you have full coverage and its not totaled shes not getting gonna be getting fixed. what happened to you is my biggest fear when im driving my '88.
                  have you had a bodyshop look at it?
                  theres really nothing else we can see unless you want to go pull the plastic off and try to open the doors to take some pics.
                    I've gotta agree with the people above, that car may well be a write-off. Perhaps not to you, but legally speaking. The b-pillar will have to be pulled out, and the frame needs to be checked out. You aren't going to be able to just bolt new doors on.
                    That said, I am 99% sure you can put the original door panels on a Crown Vic door, provided they aren't bent or broken.
                      Ouch, that looks like one heck of a hit. Good luck with the insurance garbage; I'd previously been under the impression that in at-fault states (i.e. not Michigan) it's usually considered pretty clear cut who caused the accident... though I've heard stories of unscrupulous Allstate adjusters who try to claim that all the crap that broke at the time of the collision just happened to happen at the same time, as a pure coincidence.
                      What's totalled have to do with it? Deduct the salvage value from the insurance payout and get on with it.
                      If there's any suspicion of tweakage, it might be worth getting a frame shop to look at the car. A friend of mine had a reputable bodyman put a new radiator support on a wrecked '67 Mustang, and only afterward thought to take it to a frame shop. When they tweaked the unibody back into alignment, he said that EVERY SINGLE ONE of the bodyman's welds popped!
                      Definitely don't trust only a body shop to get everything right. My dad's wife had a light collision a year or two back, and it took much screaming and yelling to get the magically knocking front halfshaft repaired as well - so evidently some idiot involved didn't take into account that things other than actual body panels are frequently damaged when a car is hit.
                        I'm going to get it fix the car only has 47,000 miles. I was just going to by a used gm with trans problem and take the parts off there. I wanted to know around how much was it going to cost for the frame.
