i am getting my car repainted with the top off and a new vinyl top going on how do i remove the old top. This is on a 2-Door Mercury Grand Marquis.
Vinyl Top Removal
Vinyl Top Removal
1982 Lincoln Continental Mark VI Bill Blass Designer Series 2-Door(Larisa)-Mods: HO Roller 302, GT40P Heads, Explorer Intakes, HO ECM(D9S), Autodimming w/compass and outside temp rearview mirror, Daniel Stern Lighting Mod, Dual Exhaust, 90's GM C/K Series Retractable Hood Light, Red Digital Dash Display, 92-94 White Leather Town Car Signature Cupholder Armrests, HPP Wheels, Police PS Cooler, Police Trans Cooler. More to come!!!!
1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.Tags: None
remove the trim around it, and start peeling. headliner needs to come out to access the nuts on the center belt trim. the rear stuff across the trunk area has little nuts inside the trunk. Side pieces I'm not sure about. Consult your shop manual, it has details for the trim installation. Not sure if those pop off or if they have slide-on rivets or what.86 Lincoln Town Car (Galactica).
once you get the vinyl off then the fun begins......you gotta get all the old glue off of the roof, this is done with some acetone or lacquer thinner and a scraper......it's messy and time consuming, the solvent will mess up the paint, so protect areas you dont want to get messed up with heavy plastic and tape
The glue is the worst part of the job. I used all kinds of chemicals for strippers. Glue removers work good, acetone, and also brake fluid. If you dont mind messing up any paint it may come in contact with.
NA-15.78@91.21, 80hp shot-14.48@96.21
also be prepared to spend a lot of time and/or money getting the bodywork under the vinyl smooth. There's probably a few dents you never knew about, and the seam on the C pillar will be pretty much totally unfinished.
bodywork isn't a big concern if the top is getting replaced though. In stock form, it is ugly under there.86 Lincoln Town Car (Galactica).
^Yea, what they said.
I had a royal PITA of a time getting the Fuzz/Glue off of my Merc's roof during the slicktop conversion. I got so sick of fucking with trying to dissolve and scrap all that nasty crap off, I just took a grinder and grinded all the shite off. Using a very light touch, so as not to remove any of the base metal, I got it done in 1 hour, and finally moved on.
