how do you spray paint the cowl i saw gadgets and would like to do that to mine.
Cowl Painting
Cowl Painting
1998 Ford Explorer Limited 5.0 AWD(Fiona)-Mods: Lincoln Navigator THX Audio System, Ford Explorer Sport Instrument Cluster.Tags: None
push the button on the top of the can. Try and point it at the surface and not your face.86 Lincoln Town Car (Galactica).
lol serious here.
what do you mean "how?"
You take apart whatever is in the way, and then follow the instructions for whatever paint you're going to cover it with.
does the whole front end have to come off
if you look at the pics of my car, the front end hasn't been removed. The cowl was painted with both fenders in place, though the hood was removed. It would be a fair bit easier to do this with the hood out of the way though. You'll want to remove all of the plastic stuff in the cowl area, but it all unscrews.86 Lincoln Town Car (Galactica).
just prepped and painted it looks good. also did the hood latch bracket and body bracket. Pics later.
nice and shiny and will never rust due to using rust-oleum paint.
only if you prepped it right.86 Lincoln Town Car (Galactica).
i did prep it sanded it down then painted it.
did you prep and paint under the radiator brackets too? I sense an overlooked spot here.
no. that's another project for tommorow i just did the top support today.
yeah... the brackets there on the top is what I meant... not the lower tie bar and all that stuff.
Originally posted by slymer View Postyeah... the brackets there on the top is what I meant... not the lower tie bar and all that stuff.
yeah i did all the top there is one more piece that needs to be spray painted then will be good.
