Hey there guys I was out at a car show and as I was leaning. . . ok well sitting on the hood and as I got off I noticed that the fiberglass fender isn't flush with the hood (my fat @$$). Is there any way I can align it back together thanks.
Front Fiberglass Fender Doesn't Sit Flush With Hood
the hood stops on the radiator support are adjustable.....adjust them up or down as needed by turning the threads on the stops.....they are those black bumper things threaded into the radiator core support
Fiberglass fender=header panel.~David~
Don't sit on your car. It can minutely stretch the sheet metal and causes large dents not immediately noticeable.
I used to sit on the roof of my car all the time. When I overhauled the body and block sanded everything I found huge, shallow dents on the roof from where I had sat. Nobody will ever sit on a vehicle of mine again.
Originally posted by CheeseSteakJim View PostI used to sit on the roof of my car all the time. When I overhauled the body and block sanded everything I found huge, shallow dents on the roof from where I had sat. Nobody will ever sit on a vehicle of mine again.86 Lincoln Town Car (Galactica).
