hopefully the hinges are not bent
Door Hinge Pin Write Up
This is a sticky topic.
-Phil
Originally posted by Lincolnmania View Postyea i lube hinges with every oil change service.....
I use axle grease on mine... nice and goopy and no rusty since it get on everything. not a clean way to do it in the slightest.
open the door... lift the door... watch the play in the hinge and look for the gaps between the hinge and pin. Check for a wear mark in the pin or ovaling of the hole in the hinge. You may require a helper for this. It has been my experience that both are worn by the time people get around to fixing them. No clue about the bushings.
Had to replace a hinge on the MM once, got a good one from a local junkyard.
Gotta love easy fixes!
Heh...
+1 love easy fixes.
