So my car is getting some body work done and recleared in a couple of weeks I want to know how to properly remove all trim to get it ready. I think we get a couple of people to get a good write up with some pictures we should sticky it or archive it cause this cause come up a couple of times but never been put all in one spot which might be useful. By the way for all body work on car and reclearing the rest $900 doesnt sound to bad to me.
All Trim Removal and Proper way to do it.
If you set up a template (like a list of what trim you have in mind to remove) I will complete it by giving all of the answers as I have removed 99% of the trim on my car.~David~
- Likes 1
900 doesn't sound all that bad, how much body work is being done?Parts Car (Scrapped) - Vicky - 1987 LTD Crown Victoria: 17x8 Gunmetal Gray Coys C-5 wheels, 235/55-17 Falken Ziex ZE-502 tires. 79 LTD Grille, Taillights, and Turn Signals, Blue LED Dash Lights, PI Rear Sway Bar, 140 MPH Speedometer, Dual Exhaust w/ Mustang Headers.
No...vinyl top is staying for now its grown on me lol plus its still brand new and dont have the cash to do it right now. As of body work goes its taking care of all the rust and the bondo thats cracking and any dings I have on the car. As for a list.
Trim Removal.
-Lower Rocker
-Roof Trim
and Everything else marked in red
and the trim around the windowsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
the rear quarter window trim is hard to take out since the molding goes on with fancy metal tabs then the window is glued in place over the tabs. you can remove the trim with the window in place but, the window might leak after due to holes in the sealer.
- Oct 2009
- 2878
- Keene NH
- Send PM
Lower rocker trim pops off, and there is a spring type clip in the back near the fender, you have to reach around and undo the acorn nut. I've never done the roof trim myself."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Lower lower rocker: Acorn nut in rear wheel well. Remove the nut then just pull the trim directly outwards working your way to the front. You will hear the popping of the clips un clipping from the lower lower rocker trim
Granny lower trim:
The front wheel wells have a couple of screws holding them in place. Remove the screws then slide the trim forward. There are slots on the back side of the trim that need to be lines up with thee clips on the car. Once they are lined up the molding comes right off. The same goes for the lower front ¼ trim and the back ¼ trim.
The door trims have two acorn nuts one in the front and one in the back. Remove those then just pull away from the door starting at one end working your way to the other.
¼ window (opera) trim: Special tool! Bend a 90 degree angle on a flat head screw driver and wrap the bend in foam and tape. Take the new tool and gently work yourself around the interior of the trim (your bend of the screw driver will be forcing upon the glass) until all of the black clips are fully shown. Then just pull it off.
Dew wipe: Remove mirror and remove door panel. Locate screws under vent window (from the inside) and at the front and rear edge of the dew wipe. Remove those three screws. Attempt to pull up on the dew wipe from either the front edge or the back edge. Be careful as it may not budge, but keep working on it and it will eventually come up and off.
If you want to know about any other pieces just ask.~David~
Resurrecting a dead thread, but starting to strip my black car down. A few areas i am having trouble with.
Back deck - Removed the sail panels and the back window trim, but there are plastic edge pieces that seem to slide but are holding the back deck down.
Header Panel - Where are the bolts? I know that they do into the fender but i am lost Do i have to remove the lights?
C pillar - How do you remove the vinyl top trim piece and the crown victoria emblem?
For the front windshield and rear window trim, is there a special tool to get it off without bending?
For the belt molding on the doors withthe dew wipe, is it just the front screw and the hidden one in the actual door then pry?
For the thin chrome between the window seal that runs along the top and the sides of the door, are these sacrificial? Do I just hammer them off with a flat head? I dont plan on reusing them.
Header panel to fender bolts are accessible from behind. Take the battery out and you'll find them, three on each side. Also two in the middle which you can see.
It's been nearly 20 years so my memory is rough here. On the c-pillar, the emblem should pry off a 88/91. I think the 87 and earlier have studs. Can't remember, check the back for a retainer and just pry if you don't see it. The lower trim is mostly clips IIRC, maybe a single bolt type in the front, the rest snap, and the rearmost I remember sliding the trim off once the others were loose.
You absolutely need a trim tool for the windshield trim. Something like this. https://www.amazon.com/GEARWRENCH-20...s%2C116&sr=8-3
The dew wipe is a the nut on the underside and the hidden screw as you mentioned. It does have clips if it's the original but I think if you pull hard enough they come off. I was not able to access them to release them. Be careful as the stuff does bend easily.
The trim around the side windows is pressed on. You can get it off better if you pull the window channel. But yes, just push towards the window opening from the outside edge.1990 Country Squire - under restoration
- Likes 1
On the header panel , I am not sure what i am doing wrong. I think i found the 3 bolts. Then the 2 by the latch, its not budging. Do i have to remove the bumper? To remove the fender, i have removed all teh top bolts including the hood brackets. Are there any bolts from the header to the fender?
There may be some screws from the bumper filler to the header panel. Should be able to see them from the bottom if they are there.
What year is your car?1990 Country Squire - under restoration
Side note on the studs in the header panel through the fender. They sometimes pull out of header panel instead of the nut coming off. If you happen to need to replace any of those studs, the perfect replacement can be found in the junkyard on whale side mirrors. Certain years have a nice hex or star head making it easy to screw the stud into the header panel. Know some years got all thread on the fender side instead of a head on the end. If that is what you find look for another year that had the head on the fender side of the stud for easy installation.Vic
Thank you for evertything. Almost done at this point. When removing the fender, there is the inner fender well. I am shacking the fender off the car and the inner fender well seems to want to come with it. Did i mis a bolt? Can i take the fenders off without removing the fender wells?
Yes. There are the little plastic rivets in the wheel wells. Maybe 7-8 per side. I had to break them to get them off. There are 2-3 bolts up near the radiator support as well. I think the battery tray comes off too, as well as the carbon canister under the battery.1990 Country Squire - under restoration
